Hi
I am guessing that many people are like me and have a lot of stuff that can be used to make other stuff, but still always seem to need even more stuff.
I also guess that again, like me, many people even have an excess of some things, although maybe not THIS much “EEVblog #737 - World’s Biggest Collection Of Electronics Components” http://www.eevblog.com/2015/04/26/eevblog-737-worlds-biggest-collection-of-electronics-components/
PROPOSAL: MHV host a swap ‘day’ to enable members (and others?) to swap stuff.
DISCUSSION:
There are many ways this could be run and organised, and plenty of precedent in swap meets aorund that could be used to set how this might work.
The hosting organisation could/should ask for a donation from attendees, either in cash or possibly a selective item donation - ie host has say over acceptability of proposed item, or cash and of course the host sets the rules!
The swapping could also just be handled online, for example in this forum, but that is less fun than a live swap and can also get messy with items still being listed after being swapped etc.
I am sure that a lot of swapping and even gifting does already happen in MHV and other spaces, but that is less efficient and haphazard as it depends on the serendipity of meeting the right person etc.
Of course swapping stuff for free is not the only way stuff can be exchanged, but it is suggested that this be the primary aim to set a more friendly non-commercial attitude.
My ideal would be a more global swap system, possibly even involving sneaker net transport, but given potential issues with ‘undesirable’ stuff being added to a shipment, a ‘trustable’ global swap system is a fairly big challenge.
To kick things off, here are my swap and want lists:
Stuff for SWAPPING:
5x 300x300 single sided PCB 1.6mm?
A4 PCB 0.6/0.8/1.0mm
A4 blank FR4 0.5mm
0.2mm blank FR4 PCB = flexible!
variety of PCB drills, & PCB milling/router & v cut bits
PCB drill set 10 – 0.3-1.3mm
PCB drill set 10 – 1.5-2.4mm
PCB drill set 10 – 2.1-3.0mm
PCB drill 2.05mm/2.15/2.25/2.85/2.95
PCB mill bits 2.0/3.0mm
V cutting 20Deg, 0.1mm tip
V cutting 20Deg, 0.2mm tip
V cutting 45Deg, 0.2mm tip
V cutting 60Deg, 0.2mm tip
Novena/MyriadRF laptop GPIO connectors FX10A-80P/8-SV 80PIN 0.5MM间距 HRS连接器 原装正品
2, 2.5mm metal & nylon bolts, various lengths ~4-12mm
pogo pins - including some that fit directly into ISP headers - need to know what drill hole you have!
SMD parts … will extra a list if there is interest
syringes (10/50cc), tips, fittings…
mechanics solder paste
small range of PCB clamps - can supply links (just not now - forum is limiting me)
FFC cables & connectors
SIL & DIL 2.54mm & some 2mm male headers -std & extra high
arduino 6P/8P/10P female headers std & extra high (~11mm)
blank project PCBs
Swarm Robot PCBs & shields (+motors/IR leds)
8x boarduino,
2x miniMite
8x Maximite,
1x SARDuino,…
2x XinCheJian badge,
2x XinCheJian motor shield
1x XinCheJian ALF {really simple no uP - old school analog only line follower}
1x IRToy PTH
1x AVR USB prog 3+ 32u4 (34u2??) swarm/Ard boards
qfp & LCD breakout PCBs
20+ Optical Drives
Server Rack Rails
Range of old Dick Smith kits (via allbids) - good for learning soldering or scavenging for part.
NOTE: kits are no longer in original packaging and some may be incomplete!
Some items have been assembled and are possibly more for loan, than swap.
USB Electrocardiograph Kit
R/C Volume Control
Programmable Flexitimer Kits
Universal Voltage Adaptor Kits
Digital Clock Timer Kits
Video Enhancer Kits
Loudspeaker Level Meter Kits
Maybe could loan large Solder paste stencil printer and JND 983A solder paste dispenser
Stuff WANTED:
current project - need to drill small holes accurately - think PCB drilling size & accuracy, so need:
- CNC, or just high speed spindle & controller (10k+ RPM)
- can be working or in need of repair, can use own drill
OR linear shaft and bearings - prefer 12 or 10mm, ~500mm x2 to start…
AND BALL SCREW linear threaded rod and fittingsOR scrappable flat bed scanners, preferably larger A3 size for parts to create above
perspex - even small offcuts 3, 2.5, 2mm, prefer clear, but any color for tests.
IR reflow oven - in the future
Pick & Place - in the future
