Space to do list
A place to keep track of current space-related projects and things that need to get done. Everyone is encouraged to jump in and help with these. Check out any unassigned projects below for ideas.
Project Assignee
Getting workshop gas heater working - needs gas canister @varvara
Fixing air compressor
Setting up card payments via Square @varvara
Migrating website to Astro and setting up online payments @varvara, @jimmy.wilmot
Putting plywood on every exposed wall surface @jimmy.wilmot
Mount first aid kit @jimmy.wilmot
Build bench and mount for tablet and square in entry way @jimmy.wilmot
Welding table @jimmy.wilmot
Cable management and the loop rationalisation @jimmy.wilmot
Kitchen deep clean
Replacing fridge with bar fridge
Clearing out hardstand space
Moving stainless table, drums and compressor @crashman39
Buy and install replacement drop saw blade - 12" @varvara
Cleaning the laser cutter lens - Maintenance Procedures · CCHS-Melbourne/Laser-Cutters Wiki · GitHub
|Project | Assignee|
|Getting workshop gas heater working - needs gas canister | @varvara|
|Fixing air compressor | |
|Setting up card payments via Square | @varvara|
|Migrating website to Astro and setting up online payments | @varvara, @jimmy.wilmot|
|Putting plywood on every exposed wall surface | @jimmy.wilmot|
|Mount first aid kit | @jimmy.wilmot|
|Build bench and mount for tablet and square in entry way | @jimmy.wilmot|
|Welding table | @jimmy.wilmot|
|Cable management and the loop rationalisation | @jimmy.wilmot|
|Replacing fridge with bar fridge | |
|Buy and install replacement drop saw blade - 12" | @varvara|
|Kitchen deep clean | @Max w.w|
|electronics room spring clean | @Max v.w Et.al|
|Design new logos and sign | @Max v.w, reviewed by Et.al|
|Prep blank nametags | @stuart|
|Prep new member welcome sheet and web content | @Max v.w, reviewed by Et.al|
|Prep new member waiver and induction SOP |—|
|Fix bandsaw | ----|
|Figure out what to do with lathe |—|
