I recently acquired a DSO (Rigol DS1074Z). I am starting to learn to use it and off the bat I encountered a problem of excessive noise.
I attached two resistors (3m3 and 3k3) to a Li-Ion battery (fully charged showing 4.1V) and measured the voltage across the small resistor. I raised the sensitivity to 1mV and could see that there are a number of frequencies present. Here are some captures.
At the highest rage there is a 100MHz signal:
Then on top of this I see a 4MHz signal
And a beat at 800KHz
I had trouble triggering on the signal, and this becase clear when I changed to 10mV resolution and could see 33KHz spikes present
Moving to the other side of the house (away from the computers) did not change the traces.
And as an aside, the four channels show very different traces. Here are all four attached to the same circuit and set up identically
Clearly, ch1 is cleanest, then ch3 and ch4, then ch2 is the worst. This is at 5mV/div
So, am I doing it wrong (probably)? Is the noise source the environment or the DSO (internal)?
If anyone has experience with these things and plans to be at the space then I can bring this over to get some help.
[later] Changing the battery to a NiMH did not change it, and on a whim I shorted all the probes (attaching the ground alligator to the tip) and got the same signal, with the probes still showing different levels despite all set to 5mV.
BTW, all measurements done with X1 setting on the probes.
I am now even more convinced that I am doing something wrong.
TIA
Eyal
