As in the shed is open in those times? I am usually busy with uni on Thursday but may be able to swing by and get it between things. If not we can work out another time. I can be free most days between 10-2
How about I get it all sorted out (acrylic/oil/varnish based, keeping/giving, …). Pretty busy ATM, but will do that by Thusrday at latest. Also prob best if I remove it from the shed (space issue as well as making sure not disposed of) and then I can drop of somtime soon, or someone collect from Page if you want sooner.
Well I managed to collect all unwanted paint, including nearly empty tins and unwanted gyproc filler etc into boot of my car. Hopefully things a bit less hectic today/weekend, so I can drop off, the most likely to be useful tins at the space sometime.
When is space likely to be open over next few days?
ps unwanted paint can now be disposed of for free at Mitchel/Mugga lane. Some limit, like 3 cans/person.
I can open the space later today if you’re able to drop it off, name a time and I’ll be there.
Otherwise not sure.
It’d probably be easiest if you gave a time that suited you and a keyholder just opened the space, as otherwise it mightn’t be opened 'till Tuesday.
