Gifts from Alastair
There are two boxes downstairs, one of LED bulbs with burned out power supplies or burned out serial elements, the other with 12VAC power supplies.
Please help yourself, I will take both boxes home with me before the working bee at the end of the month. I hope to finish the job that Alistair started of removing the functional LEDs from these units.
To clarify: these are 240V LED packages. Some have downconverters to power a small number of LEDs (three or four, you can see them in the picture). Others have a long series string of LEDs of which one has burned out (those are the ones with a heap of LEDs on the surface, one of which is black).
The 12V power supplies are for “low voltage” halogen (or “dichroic”) downlights. The two boxes of stuff are incompatible.
Photo of boxes full of stuff
