Everybody is invited along to ESP-8266 Workshop #2 at 6:30pm.
The focus of this workshop will be (Introduction to ) Toolchains + Uploading Firmware to the modules.
Anybody that missed the last workshop can come along too - and we’ll help them to catch up on trying out some of the interesting AT commands that the module supports.
I did the programming adaptor-pcb and have sent it for fabrication. I’m happy to give some out free when they are back from fabrication. They’ll have a power-LED.
Thanks to both @clixx_io and @eyal, this workshop series has worked very well (although, as we didn’t really have a plan, we couldn’t fail).
The next workshop will happen when @clixx_io next comes to town and has some new modules to share. As he says above, we’ll go over what has been learned so far in terms of getting to the point of being able to talk to the device via the different firmware images available.
This area is moving very fast, so updated or completely new firmware is likely to be available by the time we next meet (the LUA-based image we used on Wednesday was still warm from the oven!).
The other thing that seems to be moving at high speed is the number and variety of different ESP8266 modules available from ebay and aliexpress. There are (at least) 12 different versions so far, each with a different form factor, varying numbers of IO pins,with or without a built-in aerial and with or without metal shielding. If you are inclined to buy any of these, be careful to choose one suitable for your intended usage. We know that @clixx_io’s version works for uploading new firmware and doing basic “AT” commands as well as taking the LUA image, acting as a mini web server and manipulating digital IO.
After what I learned at the workshop, I tried a few more things at home.
Connected the LED board to the module:
As we saw at the workshop the initial state of that GPIO pin is high for some reason to start with. We need to initialise that GPIO pin and turn the LED off.
I then started with some LUA scripts:
This one causes the LED to flash every second controlled by the timer.
I then created a tcp/ip socket server that would turn the LED on if I sent data to port 9000 on the device:
Obviously I’ve taken one of the standard LUA examples and semi-modified it but it definitely did work.
I could then send data to the device from the command line to turn the LED on:
The result of sending that data will cause the GPIO pin to turn on.
However, cheaper and more basic is this breakout board that allows using more GPIOs with a standard breadboard if the esp-01 is too limited (use with -07, -08, -12): http://www.aliexpress.com/item/-/1817635851.html
US$2.47 for 5… I ordered a set.
Thanks for the links, @eyal . I have both the dev board and the converter boards on order (and about 20 various esp-7/esp-12 16 pin modules already). Hopefully this will spare the world more of my “dead bug” soldering attempts.
I have also read that there is a web-based IDE for the lua firmware but haven’t found it online yet.
Over the Christmas break I got a bit busy. I discovered that there’s almost a showstopper on these modules.
If you plug a peripheral that drives GPIO-0/2 to GND the module will not boot. In a production environment, boot the computer then assemble the computer - not the generally accepted way.
I spoke with friends and found the workaround for that to make it so that it will boot in typical production environments.
Now I know how to upload LUA programs to it, and drive it remotely without even using a USB Adaptor.
