Hi Brenda,
I am happy to provide all my source code/bom/reference materials for the
power monitoring that I do at my unit. Note that given the size of MHV you
would prob have to look at multiple or a much larger clamp then what I use
(I only use a 20A and I’ve never hit saturation, even with hot water + ac
at the shed)
Other ways of reducing power use is try and avoid CRTs and CFL backlit
monitors, I also found that my baseload in the unit drops by about 60-80
watts when I unplug my desktop computer and switch off my printer (though
its using wifi)
As a temporary measure most good clamp meters will give you a good measure
so you can work out your baseload. Baseload can account for a large chunk
of your power use if you let it get too high (my average baseload is around
60-80 watts, which is in the noise of my setup, and it means my minimum
power use is around 3-4 kw/hrs depending on how active I am in the morning.)
Also be worth checking what the hot water is set at and how long it takes
to heat. I am not sure where it’s located but in the shed in the parents
backyard, my hot water system accounted for about 3-4kw/hrs a day, being
set to 45C (noting the HWS was so rubbish that when set to 60C it would
trip the TPV because the thermostat would let it overshoot by about 20-30C,
at that stage it was using nearly 10kw/hrs a day and using stupendous
amounts of water)
Given that MHV is NFP it might be worth talking with the power co to see if
we can get a discount and/or be switched to TOU metering (most of our use
is in the evenings so after about 8pm we would go to “SHOULDER” which is
about 3/4 to 1/2 the price of “PEAK”)
Also check if there is any averaging b/s, given where the space is I would
assume it’d be a bit of a pain to read our meter and thus wouldn’t put it
by the meter readers to go “uhh too hard”
Computers use a butt load of power too, chugging along at 100 watts (not
including baseload), will cost 2.4kw/hrs a day which adds up pretty quickly.
Also look at point heating instead of “area” heating. Whilst it is
inconvenient to wear gloves inside if you have bad circulation in the hands
like I do, it can save alot of power (my unit leaks so much that I can’t
heat it enough to get above ~18-19C with my current fan heater without
closing all the doors to the lounge room)
I will try and do a better write up (on a break atm) with more details, but
on week days I get by on ~10kw/hrs a day, but on days when I go to
classes/go out at night/work late it gets as low as 5kw/hrs a day (I have
tastics in my bathroom)
Note that in my unit, there is no hot water on my sub switchboard (which is
where my clamp is at)
The other secret is use the right heating for the building, my shed was air
tight, I could heat it with only 800 watt hours per hour. My unit leaks air
like a cieve (more so when its windy or i am cooking due to the range hood
drawing a bloody good vacuum) so its best to use fan based heaters such as
ceramic. In the shed it was so air tight I could use an oil column heater
with no problems. Of course ALL resistive heating has a coeffecient of
1:1, but some heaters handle some conditions MUCH better than others.
In theory a “wattsclever” might work too, but bear in mind they pick up
stray fields like no tomorrow and can give erratic readings.
Last thought before my break ends… How hard given the asbestos would it
be to get ACTPG to fit a reverse cycle heatpump to the space? they run on
the smell of an oily rag (the 3kw system in the shed used only 800-900
watts and provided a peak of around 3.5kw of heat) and are waaaaaaay more
effecient than resistive heating.
Many 73s
Max
