We’re building a SatNOGS [1] [2] node at MHV. I’m carrying the cost, others welcome to contribute but mostly I’d massively appreciate help in 3D-printing the many parts this thing will take.
DONE:
UHF Helical Antenna
TODO:
We are adding our names against each part as we start prints (in the shared BOM spreadsheet on google docs) so that others know it’s being taken care of and avoids duplicating effort:
Rotator parts [here][8]
Rotator bom [here][9] (please add your name when you start a print, ask me if you can’t edit it)
Tripod parts [here][10]
Tripod bom [here][11] (please add your name when you start a print, ask me if you can’t edit it)
I demand it! Dozens of hours of printing ahead of us. I’ll set up a Google docs with things printed/yet-to-be-printed so we don’t duplicate but for the time being just post what you print here
Great to see you @Shanaek92, 3D printing is great fun and incredibly rewarding! I’d also love all the help I can get on the SatNOGS station
We didn’t have any of our usual 3D printer experts around tonight but some other new faces (many thanks to Paul & Alex!) got the Solidoodle up and running with our first successful print toward the project:
Printed these puppies(Helix437-8r3-T) tonight with a little help thanks Alex and a few new 3D printer tips for young players. Might just need to check their form with the condute to ensure that they are printed right before going on to print the last 6 or 7.
I have printed a couple of things now for this so by all means if any one else wants a go let me know and while I’m no expert I’m happy to help but it also ensures I don’t rush out and do it all.
There are two more git repositories with (supposedly) ~40-some hours of 3D printing combined, mostly in the az/el rotator box I think. No danger of running out of things to print yet, I think
Ok so tonight after some tense moments with the printer and with the pressure on from some new faces. Lol we managed to print another couple of parts after a bit of fiddling.
1 - Y connecter; and,
1 - T connector.
Leaving
1 Y connector and 6 T connectors to print for the main antenna. Hopefully I will be able to print a bit more tommorow night.
Thanks again @Paul_Buckley for doing just about all of the 3D printing so far (and @mon for doing the first trial pieces!)
@devdsp, @ian & @jambulance helping me do some tests last night - using a little FT-817 radio we made contact with another local amateur radio operator on 490.950MHz, the Isaacs Ridge repeater:
@Dexta_Bb did most of the hard work cutting & measuring three times each piece of wooden dowel (I couldn’t find any PVC in Bunnings that was 16mm, neither in plumbing or electrical supplies sections). There are some issues with the final dimensions we’ve ended up with but that was more due to the gluing process which was my fault:
Here’s the final SWR after my attempts to improve the tuning - I made it worse! I couldn’t get the antenna back to looking like that first measurement, oh well. Lucky it’s a receive antenna. I’ll try to control the spiral diameter much better next time SWR is meant to be lowest around 438MHz-ish:
