Hackaday: How to identify plastics before laser cutting
How To Identify Plastics Before Laser Cutting Them | Hackaday
Interesting
PS: the text is the Hackaday article. All I did was post the URL and “interesting”. I’m not that good a writer :smile:
If you edit the post, you can make all the text that you quoted into a ‘quote’ if you want to (select the text & click the quotes in the edit bar)
like this
Oh, I see what you mean. I wonder if putting a quote around the url will work, might not.
When I “edit” the post all I see is the URL and the text I typed!
I just tested (on your post) - and indenting the URL with > in front does change it to appear quoted in the post (I selected the link and clicked quotes menu item)
